Ok, so I seem to have gotten all of my vacuum leaks fixed, and think I have the carbs tuned pretty well... anyway, I disconnected the vacuum line at the distributor for some unknown reason with the engine running, and the RPM's climbed quite a bit but did not cause it to run rough at all. Now I'm confused... when I do the piston lift test, the RPM's do not climb like that. Also, if I disconnect the vacuum line from the manifold, it starts running rough (I figure this is because it is too much extra air). I guess I am wondering why it seems like it runs smoother with the vacuum line leaking at the distributor.
Thanks
Tony
Thanks
Tony
