mgedit
Think I have sorted out why I could not get my 56 TR3 to idle. Identified leak at intake manifold using propane. When I took manifolds off, the new gasket was clearly "compressed" at the exhaust manifold, but not at the intake. All bolts seemed snug and gaskets were new. Suspect that studs that hold the two manifolds together may have been limiting movement of intake manifold and not allowing it to seal properly. Anyone experienced this before? Are those studs essential or can I do without them? As a side note, I was surprised that the new gaskets delaminated and will need replacing. The car has not run for more than 20 minutes or so as I've fiddled with carbs, but the gaskets are toast. Is there a recommended suplier or brand of gasket that might be more durable, or is delamination just par for the course? Cheers, Mike
Hi Guest!
