V8 Conversion
69MGC
Okay, I just picked up the V8 engine that I had planned to drop into my 79 LE, but upon further consideration of trying to get the car smogged here in Calif. once the engine swap was done I've now decided that maybe it would be better to put the V8 into one of my earlier Bs. I have a 71 and a 72 that may be better candidates as they are exempt from smog checks.
My question is what engine compartment mods are needed to fit the V8 into either of the earlier cars? Is it worth making the mods or should I just drop the V8 into the 79?
Any advice is greatly appreciated.
Kevin
/ubbthreads/images/graemlins/confused.gif
Kevin....Find a copy of Roger Williams' "How to give your MGB V8 Power" (the newest edition). It has *most* everything you need to know regarding the BOP/Rover or Ford 302 conversion.
Any car before Sep '77 needs .engine compartment mods: radiator has to be moved forward, corner of firewall on driver side has to be cut & welded
[ QUOTE ]
Kevin
[/ QUOTE ]
I will email you a big article on this that I've saved from a while back. Heck..... I'll just paste it right here!
Fitting a V8 engine into an MGB
History
Some marriages are made in Heaven, but in the case of the MGB and Rover V8 engine, Ken Costello made this one in Farnborough, Kent. That the MGB was intended to receive a larger engine than the 1798cc ‘B’ series engine was always the case, from a planned, but stillborn, V4 engine in the early 1960’s to a 2.4 litre 6 cylinder ‘B’; series engine from Australia. Of course we all know about the final BMC dictate of using the 2912cc modified ‘C’ series engine, which promised lots yet delivered on balance less than the outgoing Austin Healey version.
When the major company mergers took place in the late 1960’s BMC, first became British Motor Holdings (BMH), then British Leyland Motor Corporation (BLMC), later to be shortened to BL. Whilst most that surrounded this period of restructuring was bad for MG, there is one very bright jewel. This was in the form of the Rover V8 engine, itself a Buick design that had been dropped from the General Motors range. Whilst this engine may have been expensive to build, and not big enough (capacity wise) for the US market, it was an ideal size for the smaller engined European markets, to form the basis of an executive car engine.
Certainly MG men were not slow to see various possibilities, witness the different designs put forward to replace the MGB. After all by 1970 the MGB was 8 years old, which was already longer lived than the preceding MGA. Money and politics played parts that left the MGB soldiering on with few mechanical changes, which left the market wide open for outside engineers to create conversions to improve the cars performance.
As we all know Ken Costello engineered a very effective V8 conversion, that received rave reviews in many influential motoring journals. This led to the factory being instructed to do their own conversion, and as we say, the rest is history. More recently Rover, through the foresight of Heritage producing new MGB bodies, were able to produce the MG RV8, a car which my own V8 EFi conversion played an influential part of in the early development stages.
When the factory V8 was being considered during the early 1970’s much was said about the lack of a roadster version. The official response was that the roadster shell was not strong enough, but in truth the main reason was again politics, with a roadster version being canned due to potential adverse sales conflict with cars like the Triumph TR6 and planned TR7, Jaguar E type and Triumph Stag. With the BL higher management being so apparently pro Triumph at this time it is easy to see why MG had such a raw deal, and could even give a possible pointer to explain the high pricing structure for the MGBGTV8.
The arrival of the MGRV8 puts to bed once and for all the notion that the MGB roadster body is not strong enough for the V8. It also gives an air of respectability for a number of previously frowned upon modifications, the most obvious of which is the passage of exhaust manifolds through the inner wings. Many features of the RV8 can be carried over to home V8 conversions, without the associated high costs that also afflict the RV8.
One thing that the high factory prices have done is to generate a very strong demand for conversions at more reasonable prices. Even so a properly done V8 conversion in an MGB is still not a cheap job, involving a minimum of around ÂŁ4000 (based on 1997 prices), assuming that a great deal of work is self done. It can be done cheaper if you happen to be very lucky in parts sourcing, but with such a steady demand for V8 conversion parts prices remain firm.
V8 Conversion basics
So how do we go about doing a V8 conversion? Well the first question has to be how much money do you have for the conversion? Next is how much of the work are you going to do, which has a significant bearing on overall costs? There is the question of how technically minded you are, as this will affect the depth of the modifications you can complete yourself. All these and more have to be answered before you get going otherwise you are very likely to end up as one of those adverts in the MG Mart, ‘V8 conversion, unfinished project, best offer....’
To help you decide how best to achieve your desire to arrive at V8 power, the following general guidelines will be of considerable help. These notes are predominately based on UK conditions, which means UK spec right hand drive cars and availability of certain other cars as spares. Outside the UK local conditions and legislation will have a significant bearing on any conversion and there I would suggest that contact be made with others in that locality who have already overcome all those local problems.
I categorise the conversions into two basic classes, chrome bumper conversions and rubber bumper conversions. These two groups I then sub-divide each into two further groups, depending on vehicle age. The one basic fact is that the newer the base car then the easier the conversion will be. I will cover each group starting with the easiest and working up to the most difficult.
In all of these basis comparisons I will assume that the conversion involves transposing a complete range of factory MGV8 mechanical parts into the MGB body. If other components are being considered then the impact of their dimensions and operating features can very easily alter the basic guidance given here and would require an appropriate degree of alteration to the base plan, with consideration given to any knock on effects to other sections.
Rubber bumper cars
The easiest cars to do are the rubber bumper cars. These ‘rubber’ cars fall into two separate groups, cars built between Oct 1974 and Sept 1976, then cars built after Sept 1976. Conveniently the 1976 change point coincided with various other changes to the later range, including the new dashboard, ‘deck chair’ stripped seat patterns and adoption of the rear anti roll bar as standard.
Post Sept 1976 cars (All VIN's from 410001 on)
These late rubber bumper cars featured a full under bonnet pattern exactly the same as the factory MGV8. With the MGV8 kit of parts referred too earlier this would be a bolt in conversion!
Oct 1974 to Sept 1976 cars (VIN GHN5 360301, GHD5 361001 to GHN5/GHD5 410000)
Earlier rubber bumper cars feature very many of the parts common to the MGV8, but with one significant difference. This is in the position of the radiator, which follows from the earlier chrome bumper cars. The body is modified to accept the forward mounted radiator common to the V8 and late cars, but fitting these requires the removal of the existing radiator mountings from the inner wings and welding on the late type. One other point is that the chassis mounted engine mounting brackets should be the round single bolt type, common to the V8 and later cars, however I have seen examples where the earlier 4 bolt chrome bumper type were used. If these earlier types are fitted then they have to be removed from the chassis rails and the late type fitted. Once these modification(s) are done then the fitting of a V8 follows an identical route to the post September 1976 on cars.
Chrome bumper cars
The first point to make to those wishing to end up with a chrome bumper V8 is that they should consider starting with a rubber bumper car, and convert the external look from rubber to chrome bumper. This can be done relatively easily with one of the many ‘kits’ of parts that several MG specialists sell. If some sort of body rebuild is to be included in the project, which is not an unusual situation to find with MGB bodies, then this route can have many advantages.
The main one would be if heavy cost items such as front wings were going to be replaced, as there is not any penalty by purchasing chrome bumper panels as opposed to rubber bumper panels, and the same applies to the rear wings. Full rear wings are expensive, but the difference between chrome and rubber bumper panels is negligible.
The difference between rear wings is the area under the rear lights, chrome cars have a shaped metal section which forms part of the wing. Rubber bumper cars have this eliminated to clear the rear rubber bumper assembly. The lower rear wing repair sections are available for either application, so if you only need a lower repair then there is little extra metal required to complete the chrome bumper addition under the lamps, which most ‘kits’ contain.
Now the preceding information is fine should you not yet own a donor car, but if you own a chrome car that you wish to convert, how do you achieve this? Firstly like the rubber bumper cars, the chrome bumper cars can also be sub-divided into two distinct groups. Those made from start of MGB production in 1962 to October 1967 (Mk 1), then between October 1967 and October 1974 (Mk 2 on). These two groups are easily identified as being ones that had the early three-synchro gearboxes and the later cars with the four-synchro units. The transmission tunnel being the obvious give-away, with the later cars having one with a completely flat top around the gear lever, whilst early cars had a pronounced hump in the area of the gear lever. (Only the later cars could feature the flat top centre console should you not be certain of your car.)
The modifications required for this group are considerable and should only be considered by those with a good level of skill and workshop equipment. (Or at least with access to such skill and equipment) There are a number of common modifications required and others, which will be, age dependant.
All models
The bulk of the V8 engine in terms of extra width is highlighted by the need to remove a section of each bulkhead corner to allow clearance for the rear of the V8’s cylinder heads. The passenger side (RHD or LHD) is easy, as once the required clearance is achieved then a simple closing panel has to be made up and welded in. On the steering side there is the complication that the steering shaft passes through the bulkhead in the modified area and this has to be catered for during the modification. Whilst this isn’t a body feature, it has to be mentioned that depending on what steering system is being used, then this will have a critical bearing on the actual modifications to this bulkhead.
The bulkhead area on the steering side can really follow two distinct routes. The first is the simple bolted clamp type of lower column mounting that is found in the early cars and which requires little in the way of body preparation, other than the actual clearance for the steering shaft. The other route is to use the later type of column, which utilises a three bolt fixing direct into the bulkhead. Obviously this requires some considerable care in positioning and then fixing, to ensure accuracy and strength. Once again the best reference is to use a rubber bumper car.
Whilst engaged in this area the mountings for the upper end of the column have to be catered for. The column attaches to a triangulated bracket which in turn is bolted to the under dash scuttle bracing bar and the inner side of the bulkhead panel through captive bolts. Yet again the best route to follow to achieve this is to use a rubber bumper car as the pattern.
With the bulkhead corners sorted out attention can move forward to the engine mounting affixed to the chassis rails. These are the wrong type and sit too high for the V8 so need to be removed. The simplest option is to use the genuine late rubber bumper mounting brackets, as these are the same as the factory V8 type, the RV8, and are available as a separate part.
One point that must be stressed here is that the final positioning of these engine mountings will dictate the position of the engine in the engine bay. As such areas such as bonnet clearance, exhaust clearance and fitting of all other ancillary components will be totally dependent on the accuracy of this one fitting. Where alternative components are being used, such as injection or other non-original MGV8 carburration, then due consideration has to be given to the different dimensions, as there is very limited space under the MGB bonnet (hood).
Immediately above the engine mounting on the inner wing a modification is required for exhaust manifold clearance, depending of course on what type of manifold you intend to use. Viewing any later rubber bumper/V8 will indicate that this modification is in the form of a longitudinal indent along the point where the inner wing changes from the angle to a vertical face just above the chassis rail.
Moving further forward sees the need to move the radiator towards the nose of the car, again for engine clearance. The easiest route has to be to follow the V8/rubber bumper cars by using the genuine panels. These panels include the oil cooler tray and the under support panel, which also carries the oil cooler mounting. This panel has to be modified next to each end to provide access for the through bolt used to secure the bumper mounting brackets. The use of these panels enables the V8 radiator to be fitted forward and the oil cooler (if one is to be fitted) to be mounted underneath, which helps to improve radiator efficiency.
Additionally the original radiator support bracket anchorages are now wrong and have to be removed. Once again the use of the V8/rubber bumper panels provides an obvious route, with one of these cars being used to provide a template and appropriate dimensions.
All cars may also need relief to the top of the gearbox tunnel, under the dash area, depending on the choice of gearbox, especially so if the Rover SD1 (LT77) 5 speed is to be used. This modification is common to all RV8’s that use either a late version of the SD1 box, or the redesigned R380 5 speed box. Looking down an open transmission tunnel from the engine bay end you will see that the top of the tunnel ‘steps down’ as it narrows. This step has to be moved upward to the previous level for a width of approx. 3” and rearwards to where the top of the tunnel flattens out. This also happens to be where the old speaker frame is welded to the top of the tunnel. (In the passenger area) The front step is the most problematic as it has several seams joining and welded at this point. Careful drilling of spot welds, re-forming and re-welding is probably the simplest route.
Thanks for the article Demitri. I'll read it right now. /ubbthreads/images/graemlins/savewave.gif
Thanks for the link Rick. I'll check it out. /ubbthreads/images/graemlins/grin.gif
[ QUOTE ]
Dimitri, you aren't going to modify that car of yours, are you?
[/ QUOTE ]
I don't have such plans unless Chip Foose wants to give me his treatment with my supervision.
At this point all I really want is to rehabilitate the suspension and some other areas like the steering rack/boots get some new rotors have Darrin see if we can figure out why I'm only getting 14 mpg, etc etc.
I've been in real-estate nirvana.....NOT... more like real-estate heck over the last two three months, so I've not been dropping in but about once every couple of weeks. I want to get my license for “moonlighting” purposes.
I just took a short break from it right now. While all you guys are having fun driving to Malibu I'm studying.
[ QUOTE ]
[/ QUOTE ]
No problem Kevin, anytime!!
