Using TR4 upper wishbones & balljoints on a "3"
I'm still rebuilding my front end.Apparently this gives 3 degrees more castor if you use the 4 trunnion. Does anything else on the front end need to be modified when doing this? Is there any appreciable difference in doing this mod if I'm going to a wider wheel. Might consider doing it seeing as how everything is apart. Karl
