After 4 years of restoration on a "frame off restoration", I have been working on the installation of the new interior. Removal of the old glue as been a PITA, but I am now on the top (hood) stripping the frame. I found that the HT-66 thinner works well to cause the release of old glue, but the HT-66 glue will cause the face of vinyl to deform from the rear of the material. The HT-66 thinner will also cause the top material surface and backing to separate. Regular Wellwood contact cement works initially well enough, but after time, the edges of joints turn loose. I talked to the upholstery shop who recommended that adhesive and they said they have found the same problem and solved it by two applications on the fabric, letting the first one completely dry before applying the second.
On the top header rail I ran into three different glues. One was black weatherstrip glue, one was yellow ( I suspect Wellwood), and another one was green. Does anyone know what the green glue is? It is tough to get off.
