Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
TR6...What is the recommended way to get at the drive shaft u-joints? I've been under the car trying to carefully remove the exhuast for access but can't seem to separate the pipes without damaging them.
I believe it's the same as my TR4 where I had to take out the seats and carpet to remove the trans cover to get to the forward nuts and bolts. You should have a hole in your cover to give access to yours but mine was a replacement cover that did not have the window.
