Last year I meticulously set my solenoid operating valve lift by using the 3/16 inch drill bit direction from the manual. My Overdrive was erratic, sometimes working, sometimes not. So, I pulled the interior and reset the gap wider, actually at a valve ball lift of about .027 inches. I used a dial gauge and brass tube as the Buckeye Triumph instructions suggest. It all worked great.
Now, after fixing a bad leak, I'm nervous about reinstalling the overdrive using the 3/16 drill bit fix. In fact, I'm also nervous about setting the ball lift to .027. Here's my concern.
The Workshop Manual says that the ball lift should be 1/32", and that's actually .03125 inches. So, my question is whether I can just safely set it at .03125 which is really only .004 more than I had in my prior adjustment.
Also note, however, that using the 3/16" drill bit gives a ball lift of .025, which is .006 less than I am now suggesting. Do the stainless steel balls sit differently in the valve pocket? Am I worrying about something that will never be an issue?
OK, I also have a related question. That question relates to the bottom gap between the solenoid plunger and the casting seat. The Workshop Manual suggests .015 inches with the "operated" solenoid. It takes quite an adjustment of that Allen screw to narrow up that bottom gap to .015 with the solenoid operated. I'm worried that I'm leaving it too tight or misinterpreting the instructions.
Any advice would be appreciated. Thanks all.
