jjbunn
I am looking for opinions on wire wheels for Harold, who currently has Riken basketweaves. Doc advised me that wires are more trouble than they're worth (correct me if I'm misrepresenting you, Doc). But I keep on seeing pics of MGBs with wire wheels, and I can't help but hanker for them. Just how big an operation is changing to wire wheels, anyway? Are they a bag of trouble?
Other question. Here's some symptoms of Harold's handbrake problem:
1) handbrake cable from rear axle mounting to driver's side wheel is fairly taut.
2) cable from axle mounting to passenger side wheel is slack/loose
3) handbrake cable, on underside of car where adjustment screw is, is very slack indeed.
This is all with the handbrake released. I have a feeling that the axle mount point, which is some sort of lever mechanism, may be seized, but it's hard to tell. It doesn't move readily with finger pressure. I've PB Blasted it just in case. Any thoughts on this?
Today I finally received the registration documents from the DMV for Harold, who can retain his "855 NAK" original California Blue/Yellow plates, hoorah!
