Turn Signals
barryb
Getting very close to finishing a 6 year restoration on 64 BJ8. My left side turn signal lights work correctly but right side click on but do not flash. Also, dash indicators are not working. New flasher and new flasher relay. Suggestions for troubleshooting?
Check every ground related to it. Make sure all the paint under the grounds has been removed for good contact. Check the bullet connectors. Check the wires inside the trafficator making sure they are snug. There is a chance that the new flasher or relay is bad. I found my reproduction circuit board flasher relay to be bad. I removed it and replaced it with the old points style flasher relay, problem solved. Just because something is new and improved, don't believe it.
Good luck,
Roger
