Finishing up restoration of a 1955 BN-1. I have replaced the wiring harness, used a new electronic signal box (Moss) (why they had to make it so complex???) new parking light Lucas sockets. I am using LED rear tail light bulbs with standard 1157 parking light bulbs. A regular (non electronic) flasher (I think new?) With no ballasts installed. Positive ground.
My problem is all the lights come on, but the left side parking light and tail light is 3 times brighter than the right side with no turn signal flash, left or right??
1.) I had a problem with the wiring coming from the trafficator, but when I disconnect the 3 wires (4th which is horn is OK) from the trafficator, it makes no difference, same as above.
2.) I replaced the rear LED's with 1157's and it does not change anything. Brighter left than right with no turn signal flash.
Here's what I am thinking: 1.) Better ground? 2.) Bad electronic signal box? 3.) Possible wires hooked up wrong at the signal box?
I am asking the experts for help or someone who has had similar problems????
Thank you in advance for any comments.
