I am having a problem with the turn signal circuit on my BN1. A little background info: First, the flashers are energized through their own fused circuit separate from any other load. Second, several years back I installed bulb holders in the rear reflector pods and ran the turn signal wiring to them. In other words the stock tail lights are only doing duty for running/side lights and brake lights.
In any case, when I activate the trafficator the front and rear turn signals and indicator light on the dash work, though they blink fast--about two times per second. And invariably after 10-15 minutes of driving the fuse blows and the turn signals become inoperable. When I replace the fuse the signals work again but after a few more minutes of driving the fuse blows again, ad nauseum. This happens with all size fuses up to 30 amps, so clearly something is going to dead ground.
Thinking that the problem might be from the wires in the steering column I have jacked the car up and turned the steering wheel from lock to lock while the signals are on, but I cannot replicate the failure mode. I have also jiggled all the lights and wiring at all the fixtures and at the base of the steering column while the flashers were operating but--of ours--everything was fine. The fuse only blows when I am driving the car. I have not taken the fixtures themselves apart.
Obviously I am dealing with some intermittent short but prior to tearing everything apart I wonder if some listers can me suggestions on how to approach this problem.
Hi Guest!
