T-Series turn Signal lights on MG TD
DirkRoels
Hi, I have just bought me a 52 MG TD, but as you know these cars come without turn signal lights.
Does anyone know where to buy a kit to install turn signal lights? I recall to have seen somewhere a kit that has a modern look lever installed on the steering column.
Thanks
Dirk
Dirk - First of all, you are not going to find a turn signal kit that has a modern look lever that installs on the steering column of a TD - such an animal just doesn't exist (if it ever did, it has long since expired in antiquity). You can install turn signals on a TD, but it requires a double pole, double throw relay, some new sockets for the side lights, either a single pole, double throw, center off switch or a very expensive, self canceling turn signal switch, and run some extra wires. Your best approach is to obtain the wiring diagram for a 53 TD and see how the turn signals are wired on them. If you can't find a diagram for a 53 TD, e-mail me at SUfuelpumps@donobi.net and I can send you one.
Cheers,
