AUSMHLY
Make up your mind man, are you going left or right?
I'm sure that's what the drivers behind me are thinking. Dam British driver.
So...nothing has changed. No burnt out bulbs, no me messing with any wires. It's just Lucas saying hellooooo.
The other day I noticed the left turn signal indicator on the dash was not blinking. So I moved the trafficator knob back to center then to the left. Then it worked.
I moved it to the right, then both indicators on the dash blinked. Moved it to the left and both indicators blinked.
Kept moving it, sometimes it would work correctly, only one side was blinking as it should.
So I have an intermittent problem. Right on! These are the fun ones.
Oh great ones here on the BCF, where do I start trouble shooting?
I've checked to make sure I have gas in the tank, air pressure is correct in all tires (including the spare) and my windscreen is clean. So I've ruled those areas out. However I did just post about my front shock leaking. It just happened too. I think there's a conspiracy going on.
Cheers,
Me
Cheers,
Me
