<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by TypeRboy:
Now wait a minute.. Didn't you start out by saying you wanted the Vauxhall 16V DOHC with Webers, or Del'orto's?
<hr></blockquote>
Not exactly. This thread originally started out with a mistaken reference to the motor in a Jensen Healey being of Vauxhall origin. All Jensen Healeys came with Lotus designed, Lotus Manufactured engines designated as model 907. (Some may question whether the 907 is architecturally related to a Vauxhall or not but it is definitely Lotus designed and built.) The other reference that is highly peculiar is to “weber progressives”. Progressive Weber carbs like the DGV are downdraught units. There are no downdraught manifolds for the 907 and using those downdraught to sidedraught conversion thingys wouldn’t fit under a JH’s bonnet. It would be silly anyway since the standard factory (UK JH and US Lotus) manifolds are for Dellorto DHLAs and fit Weber DCOEs.
The Opel-Vauxhall 16V, which is shared across the two sister companies’ common platforms, is an entirely different engine from the slant 4 Vauxhall that the Lotus 907 resembles. The Opel-Vauxhall 16V is an excellent motor but not available in the US. The Cosworth YB is also unusual around here. If one is willing to have a car that is only supportable through (mostly overseas) mail-order either is a great choice for an LBC.
Since the Jensen’s 907 is already a DOHC 16V all aluminum engine such substitutions would be a lot of work and logistical annoyance for little or no net gain in output.
As for the Rover/Buick V8 there is enough room for it and I have seen it done. It is also a lot of work to do well. There is no such thing as an “easy swap” among engines and transmissions that don’t share common design features. Some are easier than others. At least with the Rover/Buick you don’t need to modify a lot of the car’s sheet metal. The people who have done it do appear pleased with the results.
PC.
