healeyboz
So, I went to sink the carbs today per starting at 12 flats and working through the directions. When the piston is raised on the front it has an affect. The rear carb does nothing. Listened for the slight his and the front carb sounds like a f-16. The rear carb has a slight his that does not change when piston is lifted. Explanations?
