I get what my cam does in terms of timing. how does an uprated camshaft help?
is this something worth following up?
https://tinyurl.com/yghmany
Hairyone said:1500 cams, does anyone have any suggestions on a good cam for low to mid torque?
hi-jacking your post: for a 1275 with the standard head (valves 29mm inlet, 34mm exhaust). HIF44 carb with a little work done on it & the manifold (as per David Vizard's book).
Has anyone any suggestions for a cam to provide a good street car, i.e. low to mid torque?
The 1275 in my frow at the moment
Hap Waldrop said:JP, the cam on a 1500 is same as most of our engines, David Anton makes two street cams for 1500, I would say stay in the .400" lift area, and the duration in the 270-280 range for the street. Here's trick with 1500 when rebuilding and repalcing a cam, go with the Triumph 1300 cam, and then you can put cam bearings in your 1500 block, all BL did with the 1500 to delete cam bearings was make the cam journal big enough to fit the block minus cam bearing, so you can convert your 1500 block to cam bearing by simply getting the 1300 cam, and cam bearings from the 1300 Spitfire. The thrust bearing deal, it's not ideal, but it can be easily managed by keeping your foot off the clutch pedal at red lights, racing Triumph 1300 and 1500 don't have any thrust bearing issues, but they don't sit at red light, do they.
The poor ole 1500, has never really been given the love by the masses, but make no bones about, it has plenty of potential, Steve Sargis is proving that on the race track now with it, Sargis is easily the best American amatuer Triumph racer to ever hit the track. People build 1380cc A series hot rod engines all the time, but no one show the lowly 1500 the same attention, getting 1600cc out the 1500 is not that hard, and if the same love is shown it as the 1275s and 1380s, then a hot rodded 1500 would kick their butt. The 1550 as stated will not out rev the A series engine, but it will easily out troque it and has much greater HP potential. Mostly it was never raced and developed because the rulebooks didn't favor it well.
Hap Waldrop said:There is doubt in my mind this motor would easily have 10+ HP more than you can get out of street A series 1380.
kellysguy said:Hap Waldrop said:There is doubt in my mind this motor would easily have 10+ HP more than you can get out of street A series 1380.
Did you mean to say "no doubt"?
Hap Waldrop said:As Morris stated, you can turn down the 1500 cam to work with the 1300 cam bearing, but it's way easier just to buy the 1300 cam.
Rick Cline a well know Triumph racer devised a low cost race engine recipe years ago using the 1500, you use TR6 pistons, a standard TR6 piston is a .040" over 1500 piston as for bore size, ok with that thought, you could then you use TR6 pistons in .060" over, that would give you a .100" over 1500 or 1593cc. Now with the TR6 pistons in the 1500 you have to deck a good bit off the block, like .200", but I've have already built two .040" race engines like this and had zero problems. Port the head, (the 1500 already has some decnt valve sizes compared to the A series, 1.44" intake and 1.17 exahsut) then bump the compression to about 9.5-10.00 to 1 with a good performance street and set of Euro spec twin HS4s or a side draft Weber, a header and look out , you got a ligitimate 1380 killer. There is doubt in my mind this motor would easily have 10+ HP more than you can get out of street A series 1380.
