hermanmaire
I am trying to help out a owner of a 1964 MG. I have zero experience with these models. The car just had quite a lot of work done by a garage that though they understood these early MG's .....
- new starter ring
-clutch and throw out bearing
-valves adjusted
-carburators rebuilt with kit from Moss. All new springs installed.
ect....
The car had a electronic unit installed in the distributor a year two ago. Engine was also rebuilt by a reputable garage a few years ago so engine condition should be very good. It has great oil pressure at all RPM.
The car currently starts ( not easily though) and idles but seems really down on power. The exhaust seems to be puffing black ( which would indicate a rich mixture, I think) .
If I floor it in 1st gear ...... the thing barely moves and will probably get a few back fires in the process. If I do the same in 2nd and 3rd its also quite slow to accelerate .
I was there when the garage tried adjusting the carburetors and the only adjustment that seems to have any effect seems to only raise or lower the idle.
The engine also shakes around quite a bit at idle ( dont know if its normal) .
Any tips on what I can check to maybe help out this MG owner.....
Thanks for looking
- new starter ring
-valves adjusted
ect....
Thanks for looking
