TR6 Trunion Install
EWD
In the middle of reassembling my front suspension. 2 questions:
1. Trunion - Installing new parts. Having a problem getting the metal sleeve into the bushings. It goes easily into one side (using a vise press) but will not start into the next bushing. The sleeve catches on the edge of the bushing. (Have also tried using a bolt/washers/nut to drive it through with a drill with the same result).
2. installing new upper ball joints from Moss which come greased and sealed with no zerk. Moss recommends to keep them sealed. Thoughts?
Thanks,
Will
