wkilleffer
Hey everyone,
After alot of work and downtime, I finally got my 1974 MGB to run and drive again. It smelled like it was running rich and suffered from a richening mixture and rough idle whenever the temp gauge got to N or slightly above.
I read that the carbs need to be adjusted semi-independently, both here and in other forums. In my case, the car may be a 74, but the engine is closer to 72 and equipped with HS-type carbs. The floats in the bowls are plastic and show no sign of leakage, and the jets are grosse jets. Before the downtime due to starter failure, I got the timing set and adjusted the valve clearances, so those should not be issues.
The needles are spring-loaded.
What I have noticed is that when lifting the pistons and letting them fall, the rear carb seems to let them fall faster. The sound may be more definite, even though they both fall and hit bottom. Front carb seems slightly slower. I did this after emptying the oil from the pistons and giving everything a wipe-down with carb cleaner.
Got started by slackening the interconnection between the carbs and adjusting the idle screws 1.5 turns open. I then set the mixture screws down 10 flats from the bridge. Something I had noticed when doing this is that at a point near the bridge, the adjustment nut did not seem to be doing much. So, I gently pushed upward on the bottom of the jet, and it popped up to a point slightly above the bridge. So, I backed it down to bridge level and ten flats down (lean) from there.
The car fired right up and reached 2000 RPM, and did not take long to hit N on the temp gauge. I backed off the throttle screws half a turn at first in an orderly way until I got the idle to a point between 500 and 1000. I then used the Carbbalancer to check their breathing, and after some adjustments got them to breathe at the same rate while preserving the idle speed. The idle was a little rough and the exhaust smelled pretty rich.
At this time, I decided to use the lifting pin to check mixture on the front carb. It seemed to always be producing an indication of a rich mixture, even when I turned it almost back up to the bridge, where it came close to stalling. I backed it down 10 flats and tried the rear carb. It was rich at first, but after turning it two flats lean, I got a textbook response for the correct mixture. A slight upward idle blip, then a fall-off. I set both carbs at the same place and drove the car. It drove better, but still seemed a little off and smelled rich, though not as much as before. The rough idle with rising engine temps was less of a problem and the car would start right up when hot. Previously, starting it when it was hot could be a bit of an ordeal, like it was getting heat soaked.
Could the front carb have a needle and jet issue, like being off-center? I have an SU tool kit with a small jet wrench and a jet-centering tool, but the instructions for using that tool are not very intuitive. Also, someone on here once said that the spring-loaded needles do not need jet centering.
I am concerned about the fact that the piston will not fall as fast on the front carb, and also wonder if the adjustment problem could be caused by dirt in the front float chamber.
Any ideas or suggestions would be appreciated.
Thank you,
-William
Thank you,
-William
