twodzusfittings
Anybody on the list own a Triumph Mayflower. Looking to add additional indicators with flashers and could use some help sorting this out.
Other than what I noted in my reply, the major problem with the Mayflower is that it only has "trafficators" in the B-post.TR3driver said:Well, I don't have a Mayflower, which is probably why I don't understand the question.
Could be an issue, I guess. Still, if you can get the same number of lumens (light output) out of the lens, I'm not sure that the fixture size has that much to do with visibility. And they've got some seriously bright LEDs available these days. I was reading an article a few weeks ago talking about using them for headlights!Andrew Mace said:I just wonder if, even with a bright LED bulb, the L489 is big enough to serve well as a flasher lamp.
TR3driver said:I was just trying to present an alternative path.
