foxtrapper said:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]A bone stock GT6 will outhandle many of its period sports car peers...
It was defeated in the turns by a VW Karmen Ghia and an Opel GT.
https://members.tripod.com/~michaeljay/spitfires/cdtest/index.htm
[/QUOTE]
I have that issue of Car & Driver from which the information on that page is abridged.
It is a track test among 6 cars to yield track analysis based on rules for SCCA Showroom Stock/Sedan Class.
It was not "defeated in the turns by a VW Karmann Ghia & an Opel GT". I am assuming that refers only to the standalone skidpad test for which the graph was made.
In the track test, the C&D testers ranked the cars by their finish times on Ontario Motor Speedway 3.63 mile road course. They ranked the cars:
1. Fiat 124 Spider
2. Triumph GT6 Mk3 (0.2 seconds behind the Fiat)
3. Opel GT (0.8 seconds behind the Fiat)
4. Porsche 914 (1.5 seconds behind the Fiat)
5. MGB (5 seconds behind the Fiat)
6. Triumph Spitfire (14 seconds behind the Fiat)
That web page can be misleading where it states "The editors of C&D even gave the three fastest cars an extra advantage of the maximum legal-size rubber, from which the Spitfire did not benefit. (The GT6 did.)" The C&D article states "There's only one fissure in the rules to allow legal tuning: tires. The benefit will vary from car to car, depending upon the quality of the standard tires, so we've mounted an alternate set of maximum [SCCA SS/SC rules] legal-size rubber on the three fastest cars. From last year's tire test we know that the Semperit M401 is the best all around tire for SS/Sedan racing. In some cases, like the Triumph GT6, the change is dramatic."
They did not perform an additional test with new tires on the three slowest cars on the course; understandably, as the object was to isolate the faster cars.
In fact, the GT6's biggest problem was its original-equipment radial-ply tires.
The article states for the GT6 that "part of the deficit was traced to the sloppy steering. As is common in cars with rack & pinion steering gears, Triumph uses a rubber-isolated mounting where the gear attaches to the frame. (Generous hint: by sliding the the retaining clamps along their slotted holes in the direction that provides more preload on the rubber we were able to firm up the steering a great deal.) Then, too, there is the problem of the standard equipment Goodyear radial-ply tires. They are slow in response and not too much on what the NASCAR boys call 'side bite'. Replacing them with 165 SR-13 Semperits produced a fantastic transformation. Lap times dropped to just 0.2 seconds off those of the Fiat & they could be maintained at that level with great consistency. In addition to markedly improved cornering ability, steering response was much crisper & the brakes were more controllable."
The article does not mention whether the comparative skidpad test was done with the OE tires or with the 3 top cars using the better Semperit tires.
Nobody who's driven them will deny that a Spitfire is a zippy, fun-to-fling car, & the GT6 is very different with its greater frontward weight distribution. Both are famous for those characteristics, & both are fun & useable. Classically, the GT6 in corners technique has been move in, then stomp it & scream out for maximum bite & speed.
In the off-track tests, the GT6 did have the lowest skidpad numbers, but the highest acceleration & braking that was exactly in the middle.
All the cars had strengths & weaknesses, but note that the GT6 came in 2nd overall & just 0.2 seconds off the leader. And that in 79 hp 1973 emissions trim.
Note also that the test was of the 1973 GT6, which had the swing-spring suspension that was a cost-cutting measure & not as good as the rotoflex suspension of the GT6 Mk2/+ & earlier GT6 Mk3's.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]<div class="ubbcode-block"><div class="ubbcode-header">Quote:] The swing axle was only on the Mk1 cars in 1967. [/QUOTE]
66,67, and 73. The MK1 was swing axle, as were the later Mk3's. Although the Mk3 had a swing spring as well.[/QUOTE]
No, the Mk3's all had only rotoflex (GT6 Mk3 up to commission number KE/KF 20,000) or swing-spring (GT6 Mk3 from commission number KE/KF 20,001 until the end of production). No swing axle rear suspension was fitted to the GT6 Mk3. Swing axle was fitted only to the GT6 Mk1.
cf: part number 631410
