Trickle chargers
Rick31
Any thoughts on how long a standard trickle charger may take to charge a battery which is fairly flat? Put my 12v battery from my MGB on charge Saturday morning just gone and the charging light is still lit on the charger indicating that it is still charging. Over 48 hours now!
Seems quite a long time to me!
Depends on how fast that trickle charger is going. If it's 1 amp or less, it could take days to charge a flat battery.
My dad is a retired auto mechanic and he can keep a battery going forever. The battery is basically six containers of sulfuric acid with a plate on each side of the container. If it isn't taking a charge, disconnect the battery and carefully drop squarely on a flat surfuce such as a piece of plywood. What you are trying to do is dislodge the sulfer buildup on one of the plates. Some times you can "save" a battery for several yrs. He had one battery in his big boat over 20 yrs when he sold the boat. Also, if the charger is old, sometimes they get where they can't start charging the battery, if your charger is old, this could be a problem. Hope I didn't confuse the issue, but finally, batteries get old(usually it is this sulfer buildup) and simply need replaced.
