Henson80MGB
Another "hopefully" easy question.....
I was a good person and put the new to me 80 MGB away for the winter knowing I needed to replace the clutch slave cylinder as soon as I wanted to pull it out.
Ordered the new one for Christmas,
and started today.
1) removed old cylinder
2) installed new one
3) noticed the rubber hose going to the slave was a bit funky. (also seemed strange that the tightening "nut" on the slave cylinder side of the hose twisted the entire hose?? is that actually correct?)
4) started to bleed the clutch and got sprayed from a little hole in the rubber hose, about at the mid point.
5) Ordered new hose from Moss
6) went out to remove the old hose completely and can't figure out how to get any tool to either side of the connection to loosen and remove.
So what if any trick is there of is there "process" of removing items to get to it?
and started today.
