healeyboz
So, I got my transmission back 2 weeks ago and it still doesn't work properly. The "ticking" is gone... Whatever...
It still will not shift into gear?? It will go into 2nd and 3rd, however, it will NOT go into 1st 2nd or reverse. Neutral is still spinning the output shaft when the front is turned by hand. I know that you are supposed to be able to shift when it is dry but I am going to:
A -- Pull the side cover off and try to shift manually.
B -- Fill her full of oil and hope for the best with the neutral issue.
I hope this works or it is back off to the guy that fixed what I had wrong.
