G
As I am in the middle of a tranny, od, and clutch rebuild I had the following questions:
Thanks in advance for the answers
1. If rebuilt correctly, how long or how many miles can a person expect a 1959 BT7 transmission to function correctly barring something unexpected.
2. Can a later model Healey transmission be installed for superior performance and is that worth it.
2. Doe the overdrive use a separate oil reservoir from the transmission fluid? which has synthetic, and I understand synthetic should not be used in the overdrive.
3. Is installing a toyota tranny economical or easily adapted to the healey. I only ask this because I would rather not spend $3,000 every couple of years on rebuilding and have a fragile transmission in the meantime.
Thanks
Will
Thanks
Will
