I have a TR4 transmission that I would like to put in my '61 TR3A but it has a broken reverse gear. I received this transmission along with a lot of other parts from a PO. When I removed the top cover noticed the reverse gear was broken. After looking at the Moss catalog for the TR4 transmission I noticed the reverse gear was installed in the opposite direction (shift lever groove facing rearward instead of forward) from what's shown in the catalog. I suspect this is what caused the broken teeth on the reverse gear since it doesn't appear it would be allowed to fully engage reverse as it should. I have the shop manual for the TR3 which fully covers the '3 transmission rebuild. Is there anywhere I can get similar instructions for the '4 transmission. I have checked past threads and did not find anything. Any help would be greatly appreciated. My plan would be to rebuild this transmission over the summer and install it after the good driving weather is over. Also, other than replacing the reverse gear are there any other tips/conditions I should look for?
