healeyboz
I am rebuilding the waffled/ribbed 1275 transmission due to a few ears that were broken during a crash in the original car. I am basically transferring all of the guts from the wrecked casing to the good casing. The cases are not the same. Questions are sure to come as I rebuild this one.
Question 1:
The thrust washer on the layshaft (forward) has indents to allow springs to (i don't know) possibly pump fluid as they ride along the washer. The new casing does not have the holes for the springs to fit into. Is this a problem? Do I need to use a flat thrust washer? When I install the ENTIRE laygear assembly into the new case, will it fit?! Will the swap allow for the proper clearance that is needed?
Thanks,
Barry
Question 1:
Thanks,
Barry
