Couple of questions:
On the transmission case for my MGB there are three switches - two I've identified: reverse switch and isolation (both same size and type). There's another smaller switch on the extension for the gear shift. Can't find it in either Moss or VB. Is that for a starter interlock? The car is a '73.
Also, on the bottom of the overdrive, there is a wire coming out of the filter housing. It is/was cloth covered, and is faded and frayed, so can't tell its color. What does that connect to? There is an extra wire with a bullet connector on the new harness I got for it - maybe yellow and purple? - is that where it goes?
Thanks in advance,
Mickey
Thanks in advance,
Mickey
