Transmission oil
Which Midget do you own?
Older cars with the A-series engines (948, 1098 or 1275 cc) are supposed to use conventional motor oil (I use 5W-30 in my racer but 10W-30, straight 30W or 20W-50 are fine).
These transmissions are mostly referred to as the "ribcage" or very early "smoothcase" units.
The newer cars with the 1500 cc engine and "Marina" trans require gear oil which is typically 85W-140.
