BoneIdle
I figured I'd throw this out to the collective wisdom here:
Model:1974 GT with OD
The problem first occurred after driving 1300 miles from Tampa to Cedar Rapids. By that, I mean that I had no problems driving the 1300 miles, but after about 3 weeks here, it began to show up.
Here's what happens:
I can drive the 25 miles or so from Mechanicsville to Cedar Rapids at an average speed of 65 MPH. Typically the OD is engaged for most of the trip.
When I exit the freeway, I disengage the OD. 4th gear is fine as is the downshift to 3rd, but downshifting to 2nd is essentially te same as putting the transmission in neutral; in fact it feels as if I have shifted into neutral.
The same applies to 1st, but if I shift back into 3rd ( from 1st or 2nd ), I can tell that I'm in gear again.
Now, if I shift back into 2nd or 1st at this point, everything is working again.
Sometimes the same thing will occur on the way home, but since the last 7 or 8 miles are pretty much "non-OD" miles, more often than not, everything will be normal.
What I've done so far is to drain the transmission and OD, remove and clean the sump cover/filter for the OD and clean the OD relief valve. Of course, I refilled the transmission and OD with clean oil afterwards.
I suspect the transmission hadn't been drained in decades.
Has anyone encountered this sort of behavior before?
