AlfaHealey
Well, your original assessment was correct...the clutch is gone. I did manage to get the Healey going by putting it on jack stands and freeing up the stuck rear wheels. That lasted one extremely time until I dragged my 300 lb. buddy along and we barely were able to pull back into the driveway where the engine reved away while we just sat motionless. I checked through prior threads on clutch repairs and have a few questions: Are there any tips to make transmission removal and clutch replacement easier? Since this isn't the original transmission (center shift on 1959 100-6), do I have to dissassemble to check clutch type/size before ordering replacement? Are there any heavy duty clutches available and from where? Worth it? Are there any other things to check/do while transmission and OD are out? Can OD be checked when removed? Thanks much, Eric /ubbthreads/images/graemlins/confused.gif
Hi Guest!
