trafficator
rjc157
had to pull the trafficator because the small stator tube broke ,pulled the long one also not knowing the consequences now after finally getting the turn signals to work i can't get the horn to work any help
Hi RJ,
I don't think you've given us enough to go on here. When you say you "pulled the trafficator" did you disassemble it or pull it out as a unit?
On my 59 100-6, there are 4 wires going up the steering shaft and to the trafficator & horn.
The GREEN wire carries 12 VDC power and switches it to either
the GREEN/YELLOW for the LEFT turn signal OR to
the GREEN/BLUE wire for the RIGHT turn signal.
The BROWN with BLACK STRIPE wire carries 12VDC from the horns and grounding this wire should sound the horns.
Check to see if you have 12VDC on the BROWN with BLACK STRIPE wire.
If you do, there is a bad ground within the trafficator unit.
If you do NOT, the lack of voltage is due to an open along the wire(s) or at BOTH of the horns or at the fuse.
Tim
