I just dealt with some radiator problems last month on my TR8. My top tube split wide open. Had the tube replaced and the entire radiator cleaned out and pressure tested for $45. YMMV. Other than my new top tube the rest is still original though.
Rod, Be glad you don't have A/C in this matter. It will make pulling your old radiator and then installing the new one MUCH easier.
Scott, did you break one of the bolts for the support that goes into the subframe? Those were rather troublesome but I eventually got them in. The whole thing came apart pretty easy but was a real pain to get back together.
Before my radiator broke both fans would come on during the hot days. Usually the high speed fan will only come on when the A/C is on but mine would come on because the coolant temp would keep climbing. If I was in heavy traffic the low speed fan couldn't handle the temps on its own. Now, on hot days, and we have had a few in the mid to high 90's since, the high speed fan doesn't kick on even when I'm sitting in traffic. The low speed fan can handle the heat without issue now and when I have open roads in front of me the temp needle actually drops.
Rod, if you have upped the performance, increased compression etc..., of your engine then chances are you will need a better radiator than the stock one. Though a new core might also be able to handle it. Ted sells his exchange, Woody and Brad do like the aluminum rads, or your local shop could also re-core it. Last time I had a re-core done it was around $200 though. Often times they can improve the cooling efficiency and keep the same size on a re-core. Since they have to disassemble and then reassemble your old radiator for its tanks you get a practically new radiator. Practically because the old brass tanks have still 'work hardened' and they do become more brittle with age. That is not likely to be a problem though.
While your at it, make sure you put new hoses on when you change the radiator unless you already have new hoses.
