Finally got the radiator out, don't know how, but i did.
Only lost 2 nuts, for the coil, and found 1 bolt that i don't
know where it is from.The fan assembly pretty much stayed in place, but i found that 1 of the white plugs on the right side of the fan set up has a brunt wire on both the male and female side. I wonder if that is why TPO has a fan switch mounted under the dash. There was no plug wire going to the temp sensor on the top left side.
The radiator looks good, can't even tell where it is leaking,
i'll try and get it pressure checked tomorrow.
Any thoughts on what else i should take care of while the stuff is disconnected?
tom
tom
