RSMTR8
Ok,
Here is the latest update on my Headlight problems. They finally got all the wires that burned up replaced. Now, the headlights are almost working right, but not perfect. Here is the deal. You turn on the headlight switch, and the Drivers side healight pops right up, then, about a full second later, the passenger headlight pops up, and they both work fine. When you turn the lights off, they both go down at the same time as they should. Any suggestions?! My mechanic is recommending replacing the relays?! Any help would be greatly appreciated. Also, one other small thing when I hit the turn signal to make a left hand turn, the light on the dash does not light up or blink, I can hear it "clicking", and the right turn signal lights up and works fine, although it seems to flash fast. Any help on that would be appreciated as well!
Thanks,
Rod
rsm@loumarks.com
Thanks,
Rod
rsm@loumarks.com
