Wedge TR8 Hazard Lights
RSMTR8
Hello,
Trying to get my Hazard Lights to work. So far I have replaced the switch, and the relay. My turn signals work fine, but the hazards are completely dead. Any suggestions?!
Thanks,
Rod
rsm@loumarks.com
isn't there separate flasher units for hazard and turn signals? maybe the hazard flasher signal is inop while the turn signal flasher still works?
Yes there are separate relays, I also went through the same problem, and hazard relay was in engine compartment on drivers side skittle, turn signal was inside.
Can you be more specific on where it is located on the TR8.
Thanks!
try near the fuse box. should be near the lower left side of the fuse box. When it stops raining i can go check on my tr8 parts car. But that's where it is on my '81 DHC (tr7)
I already replaced that one. I was told that there was another one some place else? I already replaced the flasher. Thanks!
Does the horn work? I've been looking at wiring diagrams for my '76 FHC trying to figure out a short in the lighting circuit. Flashers, horns, and a few other items are fused by fuse #7 in a 12 fuse wiring harness.
Yes, the horn works. Thanks! I am stillopen to suggestions!
Rod
