The first idea was to see if a DOHC Neon\Stratus head could be made to fit on a TR7 4 cylinder block. The second idea was to see if the Triumph Stag 3.0L V8 block could take the Neon\Stratus head on one side and the Eclipse head on the other. Hmmm...
The answer is... well, almost. But I don't think so... Shucks.
The Stag V8 was designed to use the TR7 head on one side and a mirror image of the head on the other to bolt to a common block. Same situation with the Neon\Stratus and Eclipse head... only no common block. The bore spacing between the Triumph and Dodge engines are similar but the Triumph block is not symetric. The spacing between the middle cylinders is different than the outer ones. Shucks.
Well, thanks to a real gent, Mike Sullivan, I got a slightly beat up TR7 head gasket to make some comparisons with. Take a look and see what you think.
Greg
Greg
