mgb4tim
I changed the starter on my 81 FI DHC...finally. So now it fires right up, but starts to bog now at higher RPM's, like over 2,500 RPM.
The idle was always an issue, but I got info on where the set screw is, and planned on doing that next. If I try to give it gas, it starts to backfire a bit. It doesn't want to die, but just seems like it running into a rev limiter.
I checked all my plug wires, I check that long wire that goes from the distributor to the AC/Delco "coil". Tomorrow I'll try to adjust the idle to see if it runs smoothly at about 1100 RPM. If it was fuel starvation, would it backfire?
I thought it might have been because I hadn't tightened the big cable stud on the started, but it's tight, and the voltage meter reads fine, too.
It ran "fine" before the starter change, but it had one heck of a time with that old cranky starter. What gives?
