If your brakes are in proper working order, the limiting factor on stopping distance will be your tires. The best brake upgrade will be getting your stock brakes in proper working order. Smooth true rotors and drums along with good brake pads will go a long way. That being said, the TR7 brakes are barely adequate. Any track time will reveal that they do not do a good job of dissipating heat build up. Not a problem for spirited street driving or even autocrossing. A TR8 brake upgrade will help only because the TR8 parts are slightly larger, have more mass, and can absorb more heat before there is a problem. Going to a vented rotor setup with aluminum calipers would be the ultimate solution as far as being able to vent off excessive heat. A bolt on kit will run you $800 or more and will require 15 inch wheels and tires. For most drivers, this upgrade is not needed and falls under the category of car bling. The biggest issue I see on wedge brakes is lack of driving. Car sits, rotors rust, owner gets in and goes for a ride, slams on the brakes, and rust particle embed in the pad material. The rust particles cause a lack of friction between the pads and rotors. This will happen no matter what brake system you have. If the car sits, you need to pull the front wheels and sand down the rotors before you go for a ride.
