Wedge tr7 anti run on valve
philman
I noticed that i have fuel leaking from the anti-run on valve. does this mean that the carburetors (dual ZS) are over filling and sending fuel down through the charcoal cannister? If so is the float adjustment difficult to perform while carbs are on vehicle? thanks. phil
OK, I tracked down the problem to the front carberator float maladjusted, overfilling the float bowl and sending the overfill down to the charcoal cannister and out through the anti-run on valve. I did a quick adjustment in the hotel parking lot with a screwdriver, 1/2 inch wrench and a pair of pliers. All WalMart special tools. Not a perfect adjustment, but will last until I get home.
