So the sorting out of the '74 TR6 continues.
She has a wiring fault that is driving me batty - she'll start fine and then next turn of the key she'll not do anything. Totally dead. Sometimes when I disconnect the battery and the re-connect it she'll fire up like usual, next time, dead again.
When she is totally dead, there is no noise at all. No clicking from the starter, just dead air.
Battery is fresh, charged, and has a good ground.
The only thing I changed recently - and she did this <span style="font-weight: bold">before</span> I made any changes as well - was to change the points and condenser.
When she does turn over there is no spark at #1 plug or at the coil to distributor plug wire. The starter spins just fine when the power 'connects'.
This maybe be unrelated, but the reverse indicator switch pictured here is loose - the wiring diagram indicates there is a 'neutral safety switch - but I'm not sure if that would kill the power. I ask because one time when the power was dead I jiggled that switch and made sure the loose wires were not touching metal and she started. Could have been a coincidence...
Help!
Help!
