poolboy
Ok, I know you can't hear it but I'll try to describe it. It seems to be coming from the area around the right rear axle. If I make a sharp left turn or a left U- turn and once i get the car going straight again, I hear a noise that sounds like this. Swish, swish, swish etc. If I accelerate it gets a little louder and if I slow down, it goes away.
It doesn't happen every time I make a sharp left, but often enough.
It is not a metallic sound. It kind of sounds like what you hear when a tire is about to go flat. But it is a regular series of swish, swish. swish.
Could it be that the axle splines are binding and causing the tire and wheel to cant after coming out of the turn?
