Webb Sledge
My flasher unit (the one in the footwell) went bad on me a while back, and I recently bought a modern replacement from AutoZone, the 2 prong type, which is correct for my '72. In short (no pun intended), it doesn't work, which I find odd. It started spazing out right before it died. It would click even when I didn't have signals on, though I'm not sure if the signals came on by themselves when this clicking occured. I've checked all the fuses, and they're all good. Brand new wiring harness, and like I said, they were working (with the new harness in), so I know everything is hooked up right. I tried the unit with the hazards, and it worked, and I bought an ohm meter, so my fuse box is ok. I'm pretty confused. I also checked all the connections, both in the steering column and on the actual switch, and as far as I can tell, they are all have a good connection. Any thoughts?
