I need some help. I own a 69 TR6. I have the two eared type distributor. There was so much play in my old distributor shaft that the rotor was wearing the inside of the cap - badly. it was always difficult to time well, and now it is obvious why. I have a spare in fairly good condition I will be using until my old one is rebuilt. I set the point gap to 0.015. I normally run the idle at about 850. I have two questions. 1)What should the timing be set at? I have some info telling me 4 after top dead center and some telling me to set it at 12 before top dead center. Which is correct? 2)Should the vacuum line be connected or disconnected? If one line is not connected, which one do I remove and do I plug this line? Any help would greatly be appreciated.
Kevin
Kevin
