I'm trying to set the timing on my '76 TR6 and need to make certain I'm setting it correctly. The manual says I should align the timing cover pointer to the scale on the crankshaft pulley at 10 degrees ATDC. It appears that if I'm looking at the crankshaft pulley from the front I should be aligning to the 10 degree mark on the right side of the scale from the center mark. Is that right? The scale probably shows this clearly but my eyes aren't as good as they were when I was 20...
Also, should the timing be accomplished by rotating the distributor or by adjusting the micrometer adjustment nut mentioned in the shop manual.
Hi Guest!
