jjbunn
The car has a pair of rebuilt Stromberg carbs. It will start with the choke out. When warmed up it starts to run very unevenly. Pushing the choke half way in improves the idle, which settles to about 1500 rpm, but it's still a little rough. Pushing the choke all the way in, and the engine dies promptly. The engine revs very freely when the choke is out.
I topped up the dashpots with 25w50 - they were low. I noticed that the twin choke cables do not have the same position at the carbs: one carb has more choke than the other.
Do these symptoms point more towards an ignition problem or a fuel/air problem?
