TR6 TR6 Rear wheel bearing Part #'s for timken
Norton47
Hi
I just got my spare TR6 rear wheel hub pulled apart.
I used a hub puller I built using a drawing and process from on line by Tony Gordon. My final design worked well.
I haven't got the outer bearing off yet but was wondering if anyone has the Timken bearing part numbers. The inner appears to be L44649.
Also a place to buy them. plccenter.com seems to sell the inner online. Wanted to check if they had the outer but no number.
Anyone else done this.
Thanks
My Timken book lists the following for the bearings.
The inner uses a Set 4, which includes both the bearing and the race.
Outers use an LM29749 bearing and an LM29710 race.
Any good auto store, such as NAPA, should be able to get them. If not, a bearing supply house.
Jeff
My experience with bearings is to just walk into a bearing supply house, lay it on the counter and let them match it up to the lattest replacement. Often at a fraction of the cost of OE.Just beware of the chineese bearings some are inferior and others are worse!!
md(mad dog)
I cannot find a link any longer to the actual mechanical drawing.
This link https://www.geocities.com/michelotti_tr/Hub_Puller_Use_Notes.pdf
gets to the notes for using it and rebuilding hubs using it.
I have a file of the mechanical drawing and for the wrenches referenced in the above file.
It was something I found surfing when I was thinking about getting a TR6 and I think it was on a clubs website.
If I can figure out how to attach the .pdf file or someone can tell me or tell me a place to send it to, I will.
Or an email and I will send it as an attachment.
