Alan I agree with you.I have played with rear brake several times as i increased tire size which in my opinion has a lot to do(if not all) with stopping power..
When I first built my car back in 89 it had 185x15 dunlops and the brakes were adequit, then i went to a 195x15 and noticed a slight loss of brakes in the back so I took out the .70 stock wheel cyl. and put in .75 cyl.used in tr3 with 10"drums (direct replacement) if i remember right.Then I went to a 205 70r x15 and again noticed a loss of brake power.I did put on a set of 240z aluminum drums which really did,nt change anything,looked cool tho.
This winter I did the Morgan wheel cyl. upgrade with brand new alum. drums from TRF which I bought in Laughlin @Triumphest. Once the weather gets a little better i'll give them the works and see if it improved any.Be advised that the wheel cyl's. i got are not a direct replacements, some work required to fit properly, even tho many i talked claim it is direct fitting.
I do notice more freeplay in the pedal by probably
3/4 of inch or so. Will check master cyl. pushrod for clearence as discussed about a month ago,Hondo's thread i think it was.
Dale iknow what your talkin about,had similar experience with a daily driver i had for a while.
puts a lotta pressure the on sphincter muscle momentarily
phew
no long studs in there for this guy
