G
Nearly there on the stronger rears. Need some help here though as I can't get to my car until next week:
[ QUOTE ]
The area I am looking at is at the u-joint itself. It looks like the there is room in the drawings. Currently the diameter of the u-joint is 4 inches diagonally across the yokes. This is what is required to determine clearance around the axle. I am looking at modifying a drive assembly (reduced cost to you) that will actually be overkill for the engine you have but should last a long time (no failures like listed in the emails) and give you room for engine modifications. I will also need one measurement I forgot to ask. I need the length between the center of u-joint to the center of u-joint (differential joint to wheel joint) mounted in the car with the weight of the car on the wheels or a jack under the control arm. This will give me the resting operating length.
[/ QUOTE ]
Can someone please please pass me on this measurement. I'll go get it if I have to, but that's going to set the process back a week (and entail me driving 2 hours).
If at the same time you can tell me if there is 1/8" of clearance all round the outer U joint (closest to the wheel) that would also be awesome. The CV joint he's looking at requires 4 1/4".
Thanks in advance, Alan
[ QUOTE ]
[/ QUOTE ]
