Hello Everyone,
I figured out the placement of the horns (a used horn I bought had the permanent bracket reversed), I have both horns working when hooked up directly to the battery, and the solid purple lines leading to the horns are hot. The horns still do not work when I depress the horn button in the steering wheel. I had the steering wheel taken apart once to clean all the parts. I figure the problem is still in the steering wheel, but I can not figure it out what I am missing. Any suggestions?
Thanks, Kevin
Thanks, Kevin
